How to screen mirror iPhone to Sony TV?
I’m trying to screen mirror my iPhone to my Sony TV, but I’m not sure what the best method is. Does anyone know the easiest way to do this, whether through built-in features or using an app? Any tips would be really helpful. Thanks!
You can screen mirror your iPhone to a Sony TV using the built-in AirPlay feature if your TV supports it. Check here Apple TV app - Devices - Apple (EG)
Just make sure both devices are on the same Wi-Fi network, then select AirPlay from your iPhone’s Control Center to start mirroring.
If your Sony TV isn’t AirPlay-compatible, you can use apps like DoCast or Screen Mirroring for Sony TV, which are easy to set up and allow wireless mirroring from your iPhone.
You can also connect your iPhone to your Sony TV using an HDMI cable with a Lightning to HDMI adapter. This method offers a stable and high-quality connection for screen mirroring, with no need for Wi-Fi. Just plug the adapter into your iPhone, connect the HDMI cable from the adapter to your TV, and your iPhone screen will be mirrored instantly.
Also you can try using a third-party app like DoCast which provides a simple and effective way to mirror your iPhone to your Sony TV wirelessly.
