Issues with TCL Roku TV screen mirroring?
Having trouble with screen mirroring on my TCL Roku TV. I tried to mirror my phone screen, but it’s not working. The TV doesn’t recognize the connection at all. Both devices are on the same Wi-Fi network. Anyone know what might be wrong or how to fix it?
Your problem with screen mirroring on the TCL Roku TV could be down to a few things. Let’s troubleshoot this step-by-step.
  1. First, make sure both your TV and phone’s firmware are up to date. Sometimes, outdated software can cause compatibility issues.
  2. Check the mirroring settings on your Roku TV:
    • Go to Settings > System > Screen mirroring.
    • Make sure the ‘Screen mirroring mode’ is set to ‘Prompt’ or ‘Always allow’.
  3. Ensure that screen mirroring is turned on in your phone’s settings. Different phones have different names for this feature, like ‘Screen Cast’, ‘Smart View’, or ‘Cast’. Make sure you have enabled this feature.
  4. Restart both your TV and phone and then try connecting again. Sometimes, a simple reboot fixes connectivity issues.
  5. Wi-Fi networks with multiple frequencies (e.g., 2.4GHz and 5GHz) can cause confusion. Ensure that both your TV and phone are on the exact same frequency band.
If this doesn’t fix the problem, it might be worth considering an alternative screen mirroring solution. The DoCast Screen Mirroring app has been quite reliable for many users. You can download the Official Docast App from here.
The app might provide a more stable connection and better compatibility. It can work around potential firmware limitations that might be causing your current issues. Give it a try, it could save you a lot of hassle!
Let us know how it goes or if you run into any more snags!
Seriously, TCL Roku TVs are notorious for having issues with screen mirroring. It’s like they don’t even bother testing these features before selling them. Your problem with the TV not recognizing the connection is super common. Same Wi-Fi network? It doesn’t matter. Firmware updates? Pointless.
Instead of wasting time troubleshooting endless connectivity problems, try using the DoCast Screen Mirroring app. It’s not perfect, but it’s a lot more reliable than the built-in features. On the plus side, it’s easy to use and generally more stable. Downside? You might experience a bit of latency and it’s not free.
As for alternatives, there’s plenty of other apps like Miracast or AirScreen but honestly, good luck with those. They’re hit or miss too. Bottom line, TCL and Roku need to step up their game.
Check that your TCL Roku TV is in screen mirroring mode by navigating to ‘Settings’ > ‘System’ > ‘Screen Mirroring’ and ensure it’s set to ‘Always allow’ or ‘Prompt’. If it’s set to ‘Never Allow’, that might be why your phone isn’t connecting.
Additionally, try restarting both your TV and your phone. Sometimes simply resetting your devices helps. Also, make sure both your phone and TV firmware are up to date.
If that doesn’t work, it could be an issue with the specific phone model or operating system. Not all phones have perfect compatibility with every TV for screen mirroring. It might help to remember the options may differ slightly from device to device. For instance, Android’s casting feature works differently than iOS’s AirPlay.
You mentioned that both devices are on the same Wi-Fi network. Verify that there aren’t any network restrictions or additional security settings causing the issue. Some routers have settings that may block communication between devices on the same network. Try disabling any firewalls temporarily and see if it helps.
Double-check your phone’s screen mirroring settings too. Make sure the setting on your phone is turned on and looking for the TV.
In the worst-case scenario, you might consider using a third-party app. The ‘DoCast Screen Mirroring’ app is one to look into. Downloading it from the App Store could potentially solve the issue if your device is iOS. You can download it here: https://apps.apple.com/app/docast-cast-and-mirror-to-tv/id6446948344.
Lastly, if you still can’t get it to work, there might be an issue with the hardware either in your phone or the TV. Try using a different phone to see if the problem persists. If another phone works, then you know the issue lies with your phone. Conversely, if no phone works with the TV, it might be an issue with the TV itself.
Hope this helps and you get everything working smoothly!
