I’m trying to use AirPlay to mirror my iPhone screen to my TV through an Amazon Fire Stick, but I’m not sure how to set it up. I know the Fire Stick doesn’t natively support AirPlay, but I’ve heard there are ways to make it work using third-party apps or other methods. Can anyone guide me on how to do this, or recommend the best apps to use? I’d really appreciate any tips or instructions on getting this setup to work smoothly. Thanks!
To use AirPlay on Fire Stick, try DoCast or AirScreen. DoCast is easy but may have limited support, while AirScreen can work well but has ads. Install on Fire Stick, then connect your iPhone.
To use AirPlay with your iPhone on an Amazon Fire Stick, you can try third-party apps like DoCast or AirBeamTV. DoCast is easy to use but may not support all features. AirBeamTV also works, but it requires a paid version for full functionality. Install one of these apps on your Fire Stick, connect your iPhone to the same Wi-Fi network, and follow the setup instructions in the app.
