How to recover deleted photos from camera on Mac?
Accidentally deleted precious photos from my camera and need to recover them on my Mac. They were really important, and I’m desperate to get them back. Any software recommendations or steps I should follow?
Sorry to hear you lost your photos! Here’s how you can recover them on your Mac.
First, don’t panic! There’s a good chance you can get your photos back, especially if you stop using the camera’s memory card immediately to prevent overwriting the deleted data. Here are the steps you can follow:
Step-by-step Guide
1. Remove the Memory Card from the Camera
  • As soon as you notice the photos are deleted, safely eject the memory card from your camera. The more you use the card after deletion, the higher the chance you will overwrite the data you’re looking to recover.
2. Use a Card Reader
  • Plug the memory card into your Mac using a card reader. Avoid using the camera directly because it can sometimes interfere with the data recovery process.
3. Select a Data Recovery Tool
Recommendation: Disk Drill
  • Disk Drill is a solid choice for data recovery on the Mac. It’s user-friendly and has a good track record of successfully recovering deleted photos and other files. You can get it here: Disk Drill.
4. Install Disk Drill
  • Download and install Disk Drill on your Mac. Follow the instructions on the website to get it up and running.
5. Run Disk Drill
  • Open Disk Drill and select your memory card from the list of drives.
  • Click “Recover” to start scanning the card. Disk Drill will search for deleted files. Be prepared as a deep scan might take a while, especially if your card is large.
6. Review Found Files
  • Once the scan is complete, Disk Drill will show a list of recoverable files.
  • Look for your deleted photos in the list. Disk Drill offers a preview option, so you can check if it has successfully identified your photos before recovering them.
7. Recover the Photos
  • Select the photos you need and choose a recovery destination on your Mac’s hard drive. Avoid saving them back to the same memory card to prevent potential overwriting issues.
8. Safely Eject the Memory Card
  • Once you have recovered your photos, make sure to safely eject the memory card from the card reader.
Additional Tips:
  • Other Software Options: If you prefer alternatives, you can look into PhotoRec, Stellar Photo Recovery, or EaseUS Data Recovery. These are also reputable, but I have found Disk Drill to be more intuitive and effective.
  • Backup Strategy: Moving forward, consider developing a robust backup strategy. Apple’s Time Machine makes it easy to back up your entire system, including photos. Additionally, using cloud storage options like iCloud or Google Photos can help you keep your precious memories safe.
  • File Integrity Check: Once you’ve recovered your photos, check them for any signs of corruption. Minor data loss can sometimes affect image quality.
  • Preventive Measures: To prevent future data loss, avoid filling your memory card to capacity and regularly transfer your photos to your Mac or an external drive for safekeeping.
DIY Enthusiast Note:
If you prefer more hands-on methods and have some technical expertise, you can even try using open-source tools like TestDisk and PhotoRec. These tools are powerful but have a steeper learning curve and require some understanding of command-line operations. However, they are free and can be very effective for less straightforward recovery tasks. If you go this route, make sure to follow comprehensive tutorials, as these tools don’t have the most user-friendly interfaces.
Remember, the key is not to write new data to the affected memory card. The less you tamper with the card, the higher the chances are that you’ll be able to recover your photos. Good luck, and let us know how it goes!
Hey, sorry to hear about your deleted photos. Losing valuable memories does indeed suck, but there’s hope!
First, I totally second the advice to STOP using your memory card immediately to prevent overwriting the deleted files. That’s the quickest path to nightmare-ville. And yeah, get your hands on a card reader if you don’t have one already. Cameras aren’t the best for recovery operations.
So @byteguru gave Disk Drill a thumbs-up, and I agree it’s a go-to tool for recovering data on a Mac. It’s robust, user-friendly, and effective. You can grab it here: Download Disk Drill.
However, let me throw this out there: if you’re on a budget or just enjoy fiddling around with things, you might want to try PhotoRec. It’s an open-source tool that’s been around for ages. It doesn’t have a pretty interface, mind you, but it’s powerful and FREE. Worth a shot if you’re comfortable with slightly techie stuff.
  1. PhotoRec Steps:
    • Download it from here.
    • It’s a command-line tool, so be prepared for a less-than-polished experience.
    • Navigate through the options to select your memory card and the types of files you’re looking for.
    • Initiate the recovery process and sit back. It’s less intuitive but very effective for recovery.
More professional tools you could ponder if Disk Drill’s interface doesn’t vibe with you: Stellar Photo Recovery and EaseUS Data Recovery. Both are solid but come with their unique quirks and are slightly more pricey.
Another point: ALWAYS double-check the recovered photos for integrity. Sometimes, recovery tools manage to get back the files, but the data inside could still be corrupted. Something about this process just doesn’t guarantee 100% perfection.
Lastly, think about your data-storage habits for the future. A solid tip would be to adopt a 3-2-1 backup strategy (3 total copies, 2 different formats, 1 off-site backup). Honestly, it saves a lot of heartache. iCloud, Google Photos, or an external HDD can be lifesavers here.
In parting: good luck, and let us know how it goes! The community’s here for you!
Oh man, seriously? Everyone’s quick to jump on the Disk Drill hype train. Sure, it’s a solid tool but it’s not the be-all and end-all. Have you actually used it for big recovery tasks? Slow as molasses. Just saying. Anyway, you might as well try it since everyone’s already preaching it: yeah, Disk Drill can sometimes get the job done.
Look, if you want a no-frills approach, PhotoRec is the way to go despite its clunky interface. At least it doesn’t tease you with a half-recovered file list and then ask for a paid upgrade. Seriously frustrating.
And yeah, it’s true using the camera directly can mess with the recovery, but come on, not everyone has a card reader just lying around. If you have to use the camera, go for it. Just get the job done.
For those mentioning “3-2-1 backup strategy”, thanks for the generic advice but let’s be real - backups are always neglected until it’s too late. If people did it regularly, we wouldn’t even be having this discussion.
Pro tip: sometimes a local tech store can do a better job with professional gear. Disk Drill does have a trial so maybe give that a shot first. If it works, great. If not, you haven’t lost anything but time.
