How to recover data from MacBook Pro?
Accidentally deleted important files on my MacBook Pro. Tried a few recovery softwares but no luck. Need urgent help to get my data back. Any reliable methods or software suggestions?
I’ve been there and it’s definitely a stressful situation. If you’ve already tried some recovery software without success, there are still a few more approaches you can take. Let’s go through step-by-step options that might help you recover your data.
  1. Check Your Trash Bin: This might seem obvious, but make sure the files weren’t just moved to the Trash Bin. Open your Trash Bin to see if your files are there. If they are, you can simply right-click and select “Put Back”.
  2. Use Time Machine Backup: If you have Time Machine set up, you can restore your data from a previous backup. Connect your Time Machine drive, and open the Time Machine app. Find the date before you deleted the files and restore.
  3. Look for Previous Versions:
    • Open Finder and go to the folder where the files were located.
    • Right-click within the folder and select “Show View Options”.
    • Enable “Date Deleted” option to try and locate the deleted files.
  4. Disk Drill for Mac: This tool has a good reputation for recovering lost data. Download Disk Drill (Mac) from Download Disk Drill for Mac. Once installed, follow these steps:
    • Launch Disk Drill and select the drive where your files were located.
    • Click “Recover” to start scanning.
    • After the scan completes, browse through the list of recoverable files.
    • Select the files you need and save them to a different drive to prevent overwriting.
  5. Use Command Line (Terminal): If you’re comfortable with using Terminal, you can try some command line utilities.
    • Open Terminal and type: cd ~/.Trash then press Enter.
    • Use the ls command to list the contents of the Trash.
    • If you find your files, use the mv command to move them back to their original location.
  6. Check Temporary and Hidden Files:
    • Open Finder and press Cmd + Shift + . to show hidden files.
    • Look in the directory where your files were for any hidden versions.
    • You might also want to check the “~/Library” directory for auto-saved versions.
  7. Third-party Software: If Disk Drill doesn’t work for some reason, other reputable recovery tools include:
    • Data Rescue
    • Stellar Data Recovery
    • EaseUS Data Recovery Wizard
  8. Professional Data Recovery Services: If all else fails, and the data is critically important, consider using a professional data recovery service. They can be expensive but if the data is crucial, it may be worth it.
By approaching the recovery process through these steps, you maximize your chances of recovering the lost data. Always remember for future prevention, have consistent backups on your Time Machine or any other external backup system. And importantly, stop using the drive where the files were deleted to prevent overwriting.
Good luck!
Honestly, good luck with that. Most data recovery software out there is more about raising false hopes than actually helping. If you’ve already tried some and got zilch, chances are slim you’ll find magic with another one.
But on the off chance you’re looking for a last-ditch effort, Disk Drill for Mac might be your go-to. Its interface is user-friendly, but it ain’t perfect. Expect long scan times and it can be a bit buggy. You can check out more at Best Data Recovery software for Mac, but don’t get your expectations too high. Might be worth it or just another dead end.
Ugh, been there, friend. Losing files suuuucks. I’ve tried Disk Drill for Mac too, and it’s kinda hit-or-miss. It nearly gave me a heart attack last time – lots of false positives. Honestly, best bet is to check Time Machine backups if you use that. Also, try poking around in the Trash, you never know. If no dice, might be worth visiting an Apple Store or a professional data recovery service. I know it’s expensive, but sometimes it’s the only way :weary:. Good luck!
Not to state the obvious, but have you checked your Trash? Sometimes, files you think are deleted are still hanging out there. Assuming that’s not the case, you might want to give Disk Drill a try, if you haven’t already. It’s pretty reliable and user-friendly. Here’s a solid review I found: Disk Drill Review.
In terms of software, it’s got a good reputation for recovering lost files on MacBook Pros. If you’re not having luck with the ones you’ve tried, it might be worth testing it out. I’ve been in your shoes before, and Disk Drill saved me a ton of headache.
And just a quick tip: avoid writing or saving new files on your MacBook to prevent overwriting the deleted data. Good luck!
