How to AirPlay on Hisense TV?
I’m trying to figure out how to AirPlay my iPhone to my Hisense TV. I’ve tried several times, but I can’t seem to get it to work. Both devices are on the same Wi-Fi network, and I’ve updated everything, but the TV doesn’t show up as an option when I try to AirPlay. Has anyone managed to successfully mirror their Apple device to a Hisense TV? I’d appreciate any tips or solutions!
First, check if your Hisense TV supports AirPlay by visiting the official Hisense website or referring to your TV’s user manual. If your TV supports AirPlay, you can mirror your device by ensuring both your iPhone and TV are connected to the same Wi-Fi network. Then, open Control Center on your Apple device, select “Screen Mirroring,” and choose your Hisense TV from the list.
If your TV doesn’t support AirPlay, you can use a third-party mirroring app like DoCast https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344
It offers an easy setup and works well with Hisense TVs and other popular brands, providing high-quality picture during mirroring. However, the free version has a time limit.
Another app you can try is Replica, which is reliable and supports various content types. It has a free version available, though it may have occasional lag and ads.
DoCast https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344 is a good solution for mirroring your iPhone a Hisense TV, as it offers a user-friendly setup and works seamlessly with many TV brands, including Hisense. The app provides high-quality picture mirroring, making it ideal for streaming videos or sharing presentations.
Another app you can consider is AirBeamTV, which is also reliable and supports a wide range of TVs without requiring any additional hardware. It offers a straightforward way to mirror your screen, though some advanced features might require a paid version.
If you prefer a wired connection, you can also connect your iPhone or iPad to your TV using an HDMI cable and a Lightning Digital AV adapter for a stable and high-quality connection - Connect iPhone to a display with a cable – Apple Support (UK)
