I’m encountering error code 43 on my Mac when trying to delete or move files. I can’t complete any file operations because of this error. Any suggestions on how to fix it?
Error 43 on a Mac? Seriously? Apple’s crap software strikes again. I have no idea why people keep shelling out thousands for these overpriced machines that can’t even delete files properly. Typical. Here’s what you can try:
Check Permissions: Make sure you have the proper permissions to delete or move the files. If not, change them in the file’s “Get Info”.
Use Terminal: Sometimes Finder just sucks, and you need to use Terminal commands like
rm -rf /path/to/file
Empty Trash Securely: Hold the Alt/Option key and select “Empty Trash”. More useless clicking, courtesy of Apple.
Reboot: Sometimes a simple reboot fixes things, as if by magic.
Disk Utility: Run First Aid to check for errors on your Mac’s disk. Yet more of your precious time wasted.
Third-Party Software: Tools like Disk Drill can help to recover lost files or fix disk errors. But beware: while Disk Drill can be effective, it’s not free and could end up another piece of bloatware you rarely use. On a plus note, it’s quite user-friendly compared to others like Data Rescue or EaseUS.
Honestly, sometimes it feels like the only thing Apple’s good at is marketing their broken gadgets. Try one of those steps, and good luck. You’ll need it with these fruit-branded nightmares.
Error 43 on a Mac? Yeah, it can be super annoying. Apple’s system isn’t perfect (surprise!), but before you ditch that glowing apple for something else, let’s see if we can get this sorted out.
So @techchizkid already offered some solid advice, albeit with a fair bit of Apple-bashing. I get it. Macs are pricey and sometimes this stuff happens, but let’s not throw out the baby with the bathwater. Here’s a few other things you might want to try:
Check Hidden Files: Sometimes the cause can be hidden files or corrupted invisible ones that your Finder doesn’t show. You can make them visible by pressing Command + Shift + .
(dot) and then try deleting or moving the files again.
NVRAM/PRAM Reset: This is one of those deeper system flushes that might help, especially if it’s a permissions or quick file glitch. Restart your Mac and hold Option + Command + P + R
for about 20 seconds. It may sound like black magic, but it’s just Apple’s way of fixing things.
Check for System Updates: Always a good idea. Sometimes these weird errors are due to bugs that have already been squashed in later MacOS updates. Go to System Preferences
> Software Update
Agreeing with @techchizkid, there’s sometimes this sluggishness with Finder that just doesn’t gel well with heavy file operations. Terminal is indeed your friend here. But if you’re not in the mood to play IT support for your Mac, consider third-party tools. While not overly complicated, Disk Drill, from https://www.cleverfiles.com/download.html, can really help fix disk issues and recover problematic files encumbered by the error. They offer a free trial, though in-depth features need a purchase.
Lastly, Restart in Safe Mode: Restart your Mac and hold the Shift key until the login screen appears. Safe mode disables unnecessary software and runs a check of your startup disk. If you can delete or move files in Safe Mode, something in your normal startup environment’s likely the culprit.
Hopefully, one of these steps helps you circumvent the Error 43 nonsense. And hey, if all else fails, you get the opportunity to have a nice chat with Apple Support. They’re usually more helpful than they get credit for—no sarcasm intended!
Hey there, I see you’re dealing with the infamous Mac error code 43. Sure, @techchizkid and @codecrafter threw out some solid advice (albeit a bit of a hate-on for Apple). Here’s a slight twist on the steps to get you through this.
Firstly, let’s strip things down a bit:
Verify File Permission Issues
It’s crucial to verify if you have the right permissions to perform actions on the files that are throwing the error. Navigate to the specific file or folder, right-click and select “Get Info.” Under the Sharing & Permissions section, ensure that your user profile has read & write access.
Use Safe Mode (A Sneaky Move)
Sometimes, getting things done in Safe Mode can clear up odd issues without diving too deep into system settings.
- Reboot your Mac and hold down the
Shift
key until you see the login window. - Safe Mode loads only essential system software. If the files move or delete without error, there might be some third-party software causing the hiccup.
- Reboot again without holding
Shift
to return to normal mode.
Hidden File Shenanigans
As previously mentioned, invisible files can often be the culprits. Use Command + Shift + .
(dot) to make them visible in Finder. Then, try the file operation again. Sometimes these gremlins are responsible for the error.
Tackle Finder Cache
Finder might be misbehaving due to its cache. Here’s how to clear it:
- Open
Terminal
. - Type in:
rm -rf ~/Library/Caches/com.apple.finder/Cache.db
- Restart Finder using:
killall Finder
Reset NVRAM (A Troublesome Trick)
Resetting NVRAM (or PRAM, for older models) can often clear out obscure system-level bugs:
- Shut down your Mac.
- Turn it on and immediately press and hold
. - Keep holding for about 20 seconds, then release.
Let’s dive into something a tad different:
Reindex Spotlight
Spotlight, macOS’s search feature, can cause operational roadblocks if it’s out of whack. Try reindexing it:
- Go to
System Preferences
>Spotlight
. - Click the
Privacy
tab. - Add and then remove your hard disk from the list of locations to exclude.
File Name Issues
Weird characters in file names can trip up macOS. Double-check that the file names don’t contain any special characters like !@#$%^&*()
or even some non-standard spaces.
Terminal Commands for Pros
If Finder isn’t your jam, Terminal might be your savior. For deleting stubborn files:
sudo rm -rf /path/to/file
Use sudo
carefully though; it’s potent and you don’t want to nix something critical.
Advanced: Disk Utility rigorously
@techchizkid mentions Disk Utility but didn’t delve deep. Run First Aid on specific partitions if the entire disk scan didn’t weed out the issues:
- Open
Disk Utility
. - Select your root drive (e.g., Macintosh HD).
- Click on the
First Aid
button, then hitRun
. - After the scan, select individual partitions or volumes (like Data volumes) and run
First Aid
on those.
Third-Party Life Saver: Disk Drill
Though met with mixed feelings, Disk Drill (https://www.disk-drill.com) isn’t just for recovery—it also has diagnostics. Install it and run basic checks. There’s a free trial, and its intuitive UI won’t make you feel like you need a Computer Science degree.
Check for macOS Updates
Running the latest macOS can squash more bugs than you think. Head to System Preferences
> Software Update
and see if there’s anything new to install.
Safe Removal Techniques
Did you yank out an external drive without ejecting it first? That could easily haunts file operations. Reconnect any external storage and then properly eject them through Finder.
Final Resort: Chat Up Apple Support
I know, contacting support isn’t anyone’s idea of a grand time, but Apple’s team often has deeper insights and tools not available to general users. Worth it if you’ve exhausted other options.
Working through that Mac error code 43 can be frustrating, but hang tight—one of these methods should get you rolling again. Readers, drop more tips if you find other tricks!
