Recently tried to mirror my phone to my ONN Roku TV and it doesn’t work. Followed all the steps but it just won’t connect. I’m at a loss and need some help to get this working. Any tips or solutions?
Honestly, screen mirroring on Roku TVs is a complete joke. You’re not the first person having issues, and you certainly won’t be the last. It’s supposed to be straightforward, but the reality is way different.
You mentioned following all the steps, but sometimes the problem isn’t even with your TV; it’s the phone or Wi-Fi connection. But let’s face it, if you did everything right, it’s probably the wonky Roku software. They love pushing updates that mess with functionality.
Okay, here’s a somewhat viable workaround: try using the DoCast Screen Mirroring app. Yeah, I know, using another app for something your TV should be able to do natively feels like a slap in the face, but here we are. DoCast’s solid; it’s more straightforward to set up than dealing with Roku’s erratic mirroring feature. The pros are that it usually connects more reliably and even offers better compatibility with different devices. Cons? You have to pay for it; free versions are limited, and it might not be as seamless as you’d hope.
Competitors like AllCast or AirBeam should be on your radar too, but honestly, all these third-party solutions are just covering for Roku’s failures in 2023. Wouldn’t surprise me if you end up looking at those.
Screen mirroring issues on your ONN Roku TV? That’s frustrating! Let’s troubleshoot this step by step, because often it’s a small thing causing the problem.
First off, ensure both your phone and ONN Roku TV are on the same Wi-Fi network. This might sound basic, but it’s an easy oversight. If they aren’t on the same network, you’ll never get them to talk to each other.
Next, make sure your TV’s software is up to date. An outdated software version could be the culprit. Go to Settings > System > System Update and check if there are any updates available.
Now, let’s look at your phone. Phones sometimes require permissions to allow mirroring. Check that the screen mirroring setting is enabled on your phone. For Android devices, this is usually found under “Connection & sharing” or “Other wireless connections.” For iPhones, you’ll be using AirPlay, so make sure that’s enabled in your settings.
Another thing to consider is interference. If you’ve got a crowded Wi-Fi environment, that could mess up the connection. Try moving both devices closer to your router to see if that helps.
Also, sometimes it might be a compatibility issue. Screen mirroring relies on certain protocols that might not be supported universally across all devices. One way around this is to use a third-party app. I’ve had good luck with the DoCast Screen Mirroring app. It’s specifically designed to handle these kinds of connections better than the built-in options. You can find it on their official page: iPad & iPhone Cast to Roku, Chromecast, DLNA Smart TVs, and Fire TV. Give it a shot; it might solve your problem quickly!
Lastly, don’t forget the good old reboot trick. Restart both your TV and phone just to reset any temporary glitches that could be causing the issue.
If it’s still not working, reach out to Roku or ONN support. Maybe there’s something more specific to your model or software version that they can help with.
Good luck! Hope this helps.
For screen mirroring issues on your ONN Roku TV, start by ruling out some common problems that could be causing the connection to fail.
First things first, check if both your TV and your phone are connected to the same Wi-Fi network. This is a basic requirement for screen mirroring to work smoothly. Even if you’re sure they are, it won’t hurt to double-check your Wi-Fi settings.
Next, navigate to the settings on your ONN Roku TV. Go to ‘Settings’, then ‘System’, and look for ‘Screen mirroring’. Under ‘Screen mirroring mode’, make sure that it is set to ‘Always allow’. If it’s set to ‘Prompt’, your TV might be waiting for you to approve the connection, which could be why it’s not working.
Your phone’s OS plays a big part too. Ensure your phone’s software is up-to-date. If you’re using an Android device, ensure it’s running a version that supports screen mirroring. For iOS devices, you might need a specific app to mirror your screen to a Roku TV.
Here’s a step-by-step to ensure you’re setting up everything correctly:
Ensure Wi-Fi Connectivity: Verify both devices are on the same network. Sometimes switching networks (like from 5GHz to 2.4GHz or vice-versa) can make a difference.
Restart Devices: Restart both your phone and your Roku TV. This can clear up any temporary glitches in the connections.
Check Software Versions: Make sure both your Roku TV and phone have the latest updates. Roku TVs should automatically update, but you can manually check for updates on your phone.
Adjust Screen Mirroring Settings on Roku: On your Roku TV, go to Settings > System > Screen mirroring and ensure the mode is set correctly (preferably ‘Always allow’).
Try Re-Pairing Devices: Sometimes unpairing and then re-pairing the devices can help. Remove the device from your Roku’s mirrored device list and then try connecting again.
Sometimes the built-in screen mirroring might face compatibility issues or bugs that prevent it from working as expected. A reliable workaround here is using a third-party app designed for screen mirroring. I recommend the DoCast Screen Mirroring app. It’s tailored to make the mirroring process more seamless and often bypasses common glitches faced by the default methods.
You can download DoCast on the App Store via this link: DoCast on AppStore. This app can offer a more stable and user-friendly mirroring experience. It supports various TV brands and models, including Roku, so it could solve the compatibility issues you’re facing.
If you’re using an Android device and still facing issues:
- Open the ‘Settings’ app on your device.
- Tap ‘Connected Devices’ or ‘Connection Preferences’.
- Select ‘Cast’ or ‘Screen Mirroring’.
- Your Roku device should appear if both devices are on the same network. If not, tap the three-dot menu, enable the ‘Enable wireless display’ option, and see if your Roku now shows up.
For iOS:
- Swipe down to view the Control Center.
- Tap ‘Screen Mirroring’.
- Select your Roku device from the list.
One tip that often gets overlooked is updating the apps on both your TV and your phone. Some updates might contain compatibility fixes or new features that could resolve your issues. Make sure both your Roku TV and any apps you are using to cast (like YouTube, Netflix, etc.) are up to date.
Lastly, it could also be helpful to reset the Wi-Fi module in your Roku TV. This can be done by going into Settings > System > Advanced system settings > Network connection reset and then confirm the reset. You’ll have to reconnect to your Wi-Fi after this, but it could resolve underlying connectivity issues.
Each of these steps aims to either troubleshoot a common problem or configure settings to ensure seamless connection. By following these instructions and possibly utilizing the DoCast app, you should be able to get screen mirroring working on your ONN Roku TV. If none of these work, sharing more details about your setup might help pinpoint a more specific solution.
