How do I connect my iPhone to a Hisense TV?
I’m struggling to connect my iPhone to my Hisense TV. I’ve tried a few different methods, like using AirPlay and HDMI adapters, but nothing seems to work. I’m not very tech-savvy and could really use some guidance on the steps to get this done. Any help would be greatly appreciated!
Connecting your iPhone to a Hisense TV can be a bit tricky if you’re not familiar with the various methods available. Here are a few approaches you can try to get it working:
  1. AirPlay/Screen Mirroring:
    • Make sure your Hisense TV supports AirPlay. Some newer models have this feature built-in, but if it’s an older model, it might not.
    • Ensure both your iPhone and the Hisense TV are on the same Wi-Fi network.
    • On your iPhone, swipe down from the top-right corner to open the Control Center (or up from the bottom if you have an older iPhone with a Home button).
    • Tap on “Screen Mirroring” and select your Hisense TV from the list.
    • If your TV is not showing up, it’s possible that it’s not compatible with AirPlay directly.
  2. HDMI Adapter:
    • Use an Apple Lightning Digital AV Adapter (make sure it’s an official Apple adapter to avoid compatibility issues).
    • Connect the adapter to your iPhone, then connect an HDMI cable from the adapter to one of the HDMI ports on your Hisense TV.
    • Switch the input on your TV to the corresponding HDMI source.
    • This method should display your iPhone screen on your TV without much hassle, but it will mirror the entire display.
  3. Using a Casting App:
    • If AirPlay isn’t an option and the HDMI adapter still doesn’t work, another alternative would be to use a third-party app for screen mirroring.
    • One such app is DoCast Screen Mirroring, it’s designed to help mirror your iPhone screen to various TVs, including Hisense models.
    • Here’s how you can use it:
      • Download DoCast from the Appstore here: Download DoCast on Appstore.
      • Install and open the app on your iPhone.
      • Make sure your Hisense TV and iPhone are connected to the same network.
      • Follow the onboard instructions within the app to connect your iPhone to the Hisense TV.
      • Once connected, you should be able to see your iPhone display mirrored on the TV.
  4. Using DLNA Apps:
    • If your Hisense TV supports DLNA, another option is to use a DLNA app like Plex or BubbleUPnP.
    • Download the DLNA app on your iPhone.
    • Connect both your iPhone and Hisense TV to the same Wi-Fi network.
    • Use the app to scan for available devices and select your Hisense TV.
    • Stream media files (videos, photos, music) from your iPhone to your TV.
If you follow these steps and still can’t get it to work, it might be worth checking the user manual or the Hisense support page for specific compatibility notes and troubleshooting tips for your particular TV model. Sometimes software updates for your TV or even your iPhone can solve these connectivity issues.
Be aware of the compatibility between the TV and the screen mirroring feature, since certain models might not support direct mirroring and you’ll need these third-party apps. Good luck, hope this helps!
Why even bother? Hisense TVs aren’t exactly known for their compatibility with Apple products. You’ve tried AirPlay? Good luck, they barely work half the time unless you have some overpriced Apple TV. HDMI adapters? You really want to deal with more crappy cables and dodgy adapters?
You know what, if you’re really desperate, maybe try some third-party apps. Heard of the DoCast Screen Mirroring app? It claims to work across different brands but it’s a mixed bag. Sometimes works, sometimes doesn’t. On the plus side, it’s supposed to be straightforward and doesn’t need any extra hardware. But be ready for lag and occasional disconnects. Don’t expect miracles.
There are others out there too. Maybe Google Cast or some sketchy apps that might help, but you’ll probably pull your hair out trying to get them stable. At this point, smashing your TV might be less frustrating.
If you’re having trouble connecting your iPhone to your Hisense TV, there are several approaches you can try. Since you mentioned you’ve already tried AirPlay and HDMI adapters, I’ll give you some tips that might solve the issue.
First, let’s go over AirPlay again because it should be the easiest method if both devices support it:
  1. Check Compatibility: Make sure your Hisense TV model actually supports AirPlay. Not all Hisense models do, so it’s important to verify this through your TV’s manual or the Hisense website.
  2. Same Network: Both your iPhone and your TV need to be connected to the same Wi-Fi network. Double-check this because sometimes devices can end up on different networks (like 2.4GHz vs 5GHz bands).
  3. Restart Devices: Sometimes, simply restarting both your TV and iPhone can resolve connectivity issues.
  4. Enable AirPlay on TV: Go to the settings menu on your Hisense TV, find the AirPlay settings (usually under Network or General tabs) and ensure it’s turned on.
Once you’ve squared away the basics, swipe down on your iPhone screen to access the Control Center, tap the Screen Mirroring button, and select your Hisense TV from the list.
For HDMI adapters:
  1. Use Apple-Approved Hardware: Ensure that you’re using an Apple-approved HDMI adapter because third-party ones can sometimes be unreliable.
  2. Check Source Input: Make sure your TV is set to the correct HDMI input channel.
If you’ve tried all that and still no luck, consider using a third-party app like DoCast. It’s a solid option for screen mirroring and could bypass whatever issue you’re facing with AirPlay.
You can find the official DoCast app here: Official DoCast App. It’s pretty straightforward to use and often works well even when AirPlay does not.
Lastly, if none of the above works, another option is using a Chromecast device if you have one laying around. Sometimes the built-in casting features on smart TVs aren’t the most reliable, and these external devices can offer a more stable connection.
Hope one of these methods helps you out! Tech issues can be really frustrating, but persistence usually pays off.
