Hi everyone,
I’m looking to connect my iPad Pro to my TV, but I’m not sure what the best method is. Should I go for a wired connection, or are there good wireless options? Any recommendations on the best approach for high-quality video and ease of use would be appreciated. Thanks!
You can connect your iPad Pro to a TV using either a wired or wireless method. For a wired connection, use a USB-C to HDMI adapter, which ensures high-quality video and stable performance. Read more here Connect iPad to a display with a cable - Apple Support (LK)
If you prefer going wireless, you can use AirPlay if your TV supports it, or try apps like DoCast or ApowerMirror, which work with most smart TVs.
Both methods are easy to set up and work well for mirroring your iPad Pro screen to your TV.
Another way to connect your iPad Pro to a TV is by using an Apple TV or an AirPlay-compatible smart TV for wireless mirroring, which is easy and convenient. If your TV isn’t AirPlay-compatible, you can use a USB-C to HDMI adapter for a reliable wired connection.
Additionally, apps like LetsView, Smart View or DoCast can also be used for wireless mirroring on many smart TVs. All of these options are simple and effective for getting your iPad Pro content onto the big screen.
